January 1970 - December 1970
Bulletin No. 138 - April 24, 1970 [COMPLETE]
(37 articles)
  • Article 2264 - Ordering Procedure
    Special Service Tools vs. Rotunda Equipment
  • Article 2265 - Master Cylinder Bore Specification Correction - 1969 Cortina Shop Manual
    (Cortina - 1969)
  • Article 2266 - Disc Brake Noise Correction
    (THIS ARTICLE CANCELS AND SUPERSEDES TSB NO. 131 ARTICLE 2050 DATED 1/16/70 AND TSB 133, ARTICLE 2123 DATED 2/13/70)
    (All Car Lines Except H/D Police - 1969-1970)
  • Article 2267 - Disc Brake Vibration
    (All Passenger Cars with Disc Brakes except Cortina)
  • Article 2268 - Service Campaign H-81 - Announced 11/17/69
    (Early 1970 Mustangs equipped with 14" x 7" or 15" x 7" wheels)
  • Article 2269 - Front End Noise Due to Coil Spring and Rebound Bumper Contact
    (F100-250 Trucks - 1968-70)
  • Article 2270 - Front Wheel Alignment Charts - Revision
    (Light Trucks [4x4] - P Series - Bronco)
  • Article 2271 - Rear Suspension Bottoming
    (1970 Fairlane except w/9" Axle)
  • Article 2272 - Loose Crossmember Bolts
    (All "L" Series)
  • Article 2273 - Service Campaign H-91 - Announced December 16, 1969
    (Certain 1969-1970 "W" Series Highway Tractors)
  • Article 2274 - Power Steering Hose Contacts Radiator Hose - L Series
    (LT & LNT with 16,000 and 20,000 Pound Front Axles and 8V-71 or 6-71 Detroit Diesel Engines - 1970)
  • Article 2275 - Service Campaign H-95 - Announced March 12, 1970
    (Early 1970 L & LT 800, 8000, 900, 9000 Series Ford Trucks with Power Steering)
  • Article 2276 - Power Steering Pumps - Identification of Incompletely Processed Upper Pressure Plates
    (All Cars Using TRW Pumps - 1970)
  • Article 2277 - Manual Transmission Lubricant Specification Change
    (All P350 thru P5000 with Manual Transmission - 1970)
  • Article 2278 - Automatic Transmission - Delayed or Erratic Shift Points
    (All Units with Automatic Transmission - 1970)
  • Article 2279 - Automatic Transmission - Reverse Clutch Pressure Plate Rebuilding
    (All Cars or Trucks with C-6 - 1970)
  • Article 2280 - Engine Performance Specifications - Revision
    (All 1970 Trucks Equipped with Gasoline Engines)
  • Article 2281 - Improved Turbocharger Oil Drain Hose Routing - L Series
    (L & LN 9000 Series Trucks Equipped with Cummins NTC-335 Diesel Engine - 1970)
  • Article 2282 - Fuel Line Routing - L Series
    (L 9000 Series Truck with 6-71 Detroit Diesel Engine and Single L.H. Fuel Tank)
  • Article 2283 - Hard Cold Starting
    (F100 and Bronco with 6 Cylinder Engine - 1970)
  • Article 2284 - Battery Cable Routing - "L" Series - Improved
    ("L" and "LT" Series Truck with Detroit Diesel 8V-71 Engines - 1970 Model)
  • Article 2285 - Wiring - Correction to Shop Manual & Wiring Diagram
    (Cortina - 1970)
  • Article 2286 - Alternator Regulator Wiring Harness Routing - LN Series - Improved
    (LN & LNT Series Trucks with Super Duty Gasoline Engines - 1970)
  • Article 2287 - Fender Mounted Turn Signal Lens Loose When Reassembled - L Series
    (L Series Truck - 1970)
  • Article 2288 - Bulb Chart Revision - 1970 Car Shop Manual and 1970 Specifications Booklet
    (Mustang - 1970)
  • Article 2289 - Roof Marker Lamp Switch Retention - L Series
    (All L Series Trucks - 1970)
  • Article 2290 - Heater or A/C Blower and Motor Removal
    (Ford - 1970)
  • Article 2291 - Windshield Wiper Motor Output Arm Removal
    (Ford 1970)
  • Article 2292 - Automatic Temperature Control Box Noisy
    (Thunderbird - 1969 and 1970)
  • Article 2293 - Water Leaks - Passenger Compartment
    (Cortina - 1970)
  • Article 2294 - Service Campaign H-80 - Announced September 3, 1969
    (Early 1970 Fords, Fairlanes and Mustangs Equipped with Standard Seat Belts)
  • Article 2295 - Service Campaign H-82, Announced 9/9/69
    (Early 1970 Thunderbirds, Fords, Fairlanes and Mustangs Equipped with Deluxe Seat Belts)
  • Article 2296 - Service Campaign H-88 - Announced 9/12/69
    (Early Production 1970 Fairlanes Model 63 - Sports Roof)
  • Article 2297 - Deck Lid Lock Cylinder Cover - Rattle
    (Thunderbird - 1970)
  • Article 2298 - "L" Series Floor Pan Deflection - Floor-Mounted Orscheln Parking Brake Mounting
    (All "L" Series with Orscheln Brake)
  • Article 2299 - Seat Belts - Special Long Length
    (All 1970 Carlines)
  • Article 2300 - Spare Tire Support Bolt Stripped or Galled
    (F100-350 and P350-400 with Frame Tire Carrier - 1969-1970)
cron
