January 1971 - December 1971
Bulletin No. 157 - January 22, 1971 [COMPLETE]
(18 articles)
  • Article 3244 - Disc Brake Rotor Refinishing Tools - (All Passenger cars - 1968-71)
  • Article 3245 - Reducing Steering Effort on "Steerease" - (L-LT-LTS-LN-800-900 and 8000-9000 Series Trucks with a 12,000-Lb. Capacity "Steerease" Front Axle)
  • Article 3246 - Front Wheel Alignment Specification Revision - (Pinto - 1971)
  • Article 3247 - Clutch Pilot Bearing Noise - Light Truck - (F100-F350 Truck with 8-Cylinder [360-390 CID] Engines and Standard Transmission - 1970-71)
  • Article 3248 - 4-Speed Transmission - Oil Leaks - (Pinto - 1971)
  • Article 3249 - New Solid Mainshaft - Fuller RT-910-915 Transmissions - (All Extra Heavy Trucks with Fuller RT 910 or RT 915 Series Transmissions - 1971 Models)
  • Article 3250 - Clutch Housing to Flywheel Housing Attaching Bolts - (All 9000 Series Trucks with 8V-71 Engines and 16-Speed Spicer Transmissions - 1970-71 Models)
  • Article 3251 - Automatic Transmission Converter and Oil Cooler Cleaning - (All Vehicles Equipped with an Automatic Transmission)
  • Article 3252 - C4 Automatic Transmission - Valve Body Separator Plate Gasket - (Pinto with C4 Automatic - 1971)
  • Article 3253 - FMX Automatic Transmission - Output Shaft Bearing Change - (Ford, Torino, Mustang with FMX - 1971)
  • Article 3254 - Camshaft Spacer Incorporated with Camshaft Sprocket - (Car Vehicles Equipped with 390 and 428 V-8 Engines; Truck Vehicles Equipped with 330, 360, 361, 390 and 391 V-8 Engines)
  • Article 3255 - Loose Front Engine Mount - New Bolt - L & W Series - (L, LN, LNT, LT, LTS, W, WT-9000 with NH, NHC, NTC & 8V-71 Diesel Engines - 1970)
  • Article 3256 - Revised Fuel Pump Flow Specifications - (All Trucks Equipped with In-Tank Electric Fuel Pump)
  • Article 3257 - 2V Carburetor - Hesitation on Acceleration - (All with 351C, 351W or 400 CID Engines - 1971)
  • Article 3258 - Engine to Radiator Aspirator Hose Chafes on Air Cleaner Flange (THIS ARTICLE CANCELS AND SUPERSEDES ARTICLE 2371, BULLETIN 143) - (L-Series Trucks with Cummins NTC and NHCT Engines - 1970)
  • Article 3259 - Air Conditioner Evaporator Drain Tube Improperly Installed - (Pinto - 1971)
  • Article 3260 - Starter Relay Solenoid Switch Replacement - (Pinto - 1971)
  • Article 3261 - Hood Restraining Cable Clevis Insulator - (All "L" Series - 1970-1971)
cron
