January 1971 - December 1971
Bulletin No. 158 - January 29, 1971 [COMPLETE]
(25 articles)
  • Article 3262 - Pre-Delivery Check of Dry Type Air Cleaner Element
    (All Trucks Equipped with Dry Type Air Cleaner)
  • Article 3263 - New M.G.M. "Low Profile" Rear Wheel Service and Spring Brake Chamber
    (L-Series Tandems with 30,000, 34,000 and 38,000-Pound Capacity rear Axles, 34,000-Pound Capacity Suspensions and Bendix Wedge Air Brakes)
  • Article 3264 - Flywheel Housing Misalignment
    (Pinto with Manual Transmission - 1971)
  • Article 3265 - Clutch Free Play Adjustment
  • Article 3266 - Clutch Disc
    (Pinto - 1971)
  • Article 3267 - Automatic Transmission Shift Speed Charts - Revised
    (All Vehicles Equipped with a C4 Automatic Transmission - 1970 and 1971)
  • Article 3268 - Brake Pedal Noise
    (Ford - 1971)
  • Article 3269 - Caliper Mounting Bolt Replacement
    (All Passenger Cars with Disc Brakes - 1971)
  • Article 3270 - Engine Specifications
    (Pinto 2000cc - 1971)
  • Article 3271 - Cylinder Head Bolt Torque
    (Pinto with 2000cc Engine - 1971)
  • Article 3272 - Timing Belt Tensioner - New Design - Engine
  • Article 3273 - Oil Filter Seal - Blown Out - Engine
    (Pinto with 1600cc Engine - 1971)
  • Article 3274 - Improved Fuel Leveling - W Series Trucks
    (W-WT-9000 Trucks with 671N & 8V-71 Engines and 100-Gallon Tanks - 1970)
  • Article 3275 - Exhaust System Clamp Usage
    (All Cars - 1971)
  • Article 3276 - Radiator Side Air Deflector
    (All "L" Series Trucks)
  • Article 3277 - New Fan Assembly
    (All C-6000-7000-8000 Trucks with Caterpillar V-8 Diesel Engines)
  • Article 3278 - Aeration and Loss of Engine Coolant
    ("L" Series Trucks with Super Duty Engines - 1970)
  • Article 3279 - New Fan Shrouds
    (F-B-C-500-750; F-B-C-6000-8000 Trucks)
  • Article 3280 - Relay to Starter Cable - Routing
    (Ford with 400 CID Engines - 1971)
  • Article 3281 - Engine Dieseling
    (All Models Equipped with Throttle Solenoid Positioner and Alternator Indicator Light - 1970/1971)
  • Article 3282 - Back-Up Lamp Switch Replacement - 1969 Light Truck and Bronco
    (F100/350 and Bronco with Standard Transmission - 1969)
  • Article 3283 - Heater - Operational Characteristics
    (Ford Equipped with Integral Heater-A/C - 1971)
  • Article 3284 - Front Seat - Increasing Cushion Height
    (Mustang Models 63-65D - 1971)
  • Article 3285 - Package Tray Panel vibrates and Rattles
    (Maverick - Model 54 - 1971)
  • Article 3286 - Convertible Top Binds at No. 2 Bow
    (Mustang Convertible - 1971)
cron
