- - Article 3338 - Brake Linings - Improved - (E100 and E300 - 1969-1971; F250 and F350 - 1967-1971)
- Article 3339 - Rack & Pinion Steering Gear - Diagnostics Procedure - SUPERSEDES ARTICLE 3314, TSB 160, DATED FEBRUARY 26, 1971 - (Pinto - 1971)
- Article 3340 - Power Steering Pump Noisy - (Thunderbird - 1971)
- Article 3341 - Shift Lever "Grounds Out" in Fourth Gear - (Mustang with 4-Speed Manual Transmission - 1971)
- Article 3342 - Exhaust System Noise or Rattle - (Thunderbird - 1971)
- Article 3343 - Horn Switches - Service Procedure - (All Passenger cars - 1970-1971)
- Article 3344 - Tip-In-Moan Correction - SUPERSEDES ARTICLE 3219, TSB 156, DATED DECEMBER 18, 1970) - (Ford with 8-Cylinder Engines - 1971)
- Article 3345 - Valve Guide Repair Bushings - New - (6 and 8-Cylinder Engines - All Passenger Cars except 289 C.I.D. H/P and 428 C.I.D. P/I)
- Article 3346 - Timing Belt Tensioner and Timing Belt - Removal and Installation Procedure - (Pinto - 2000cc Engine - 1971)
- Article 3347 - Lack of Power - (401, 477 & 534 CID Super Duty Gasoline Engines in Heavy Duty Trucks - 1969-1971)
- Article 3348 - Decel Adjustment - (Pinto - 1600cc Engine - 1971)
- Article 3349 - Rough Engine Idle - (Pinto with 2.0L Engine, Automatic Transmission, and Air Conditioning & Weber Carburetor Tag - D1ZC-CA - 1971)
- Article 3350 - Accelerating Pump Rod Retainer - Service Procedure - (Ford with 2V Carburetor - 1971)
- Article 3351 - Cooling System - Boss 351 - (Mustang - 1971)
- Article 3352 - Starter Cable - Improved Routing - (L-Series Built Prior to 2-19-71 with Super-Duty Engine)
- Article 3353 - Power Windows and Air Conditioning System Inoperative - THIS ARTICLE SUPERSEDES ARTICLE 3209, TSB NO 155 - (Thunderbird - 1970-71)
- Article 3354 - Radio System Problem Diagnosis - (All Vehicles Equipped with Radio, Multiplex, or Stereo Tape System - All Model Years)
- Article 3355 - Heater Core Leaks - Diagnosis Procedure - (Pinto, Maverick and Mustang with Standard Heater or A/C - 1971)
- Article 3356 - Automatic Temperature Control Box Test Procedure Correction - (Ford wit ATC - 1971)
- Article 3357 - Air Conditioning Selector Valve Vacuum Leaks - (Ford with Manual A/C - 1971)
- Article 3358 - Air Conditioning Evaporator case Support Stress Cracks - (Pinto - Equipped with A/C - 1971)
- Article 3359 - Power Windows Inoperative - Water Contamination to the Relay - (Thunderbird - All with Power Windows - 1971)
- Article 3360 - Power Window Switch Wiring Connector Removal and Replacement (Single Switch) - (Ford - Equipped with power Windows - All except "K" Models - 1971)
- Article 3361 - Rattle or Vibration Noise Under Dash - Light Truck - (F100/350 - 1971)
- Article 3362 - Tailgate Window Washer/Wiper Operation Improvement - (Ford Station Wagon Equipped with rear Window Washer - 1971)
- Article 3363 - Vinyl Roof Cover - Poor Appearance "A" Pillar Seam Edge - (Ford, Pinto, Maverick and Thunderbird Model 65 - All Vehicles with Vinyl Roof Covers - 1971)
- Article 3364 - Bogie Support Crossmember to Lower Gusset Fasteners - (Tandems with Steel Gusset - "L" Series - 1970)
