January 1971 - December 1971
Bulletin No. 163 - April 9, 1971
(24 articles)
    - Article 3390 - Truck Engine Code Identification - (All Light and Medium Trucks - 1971)
    - Article 3391 - Motor Vehicle Clean Air Act Amendment - (All Passenger Cars - 1971)
    - Article 3392 - Pinto Air Cleaner Damage During Removal - (Pinto - 1971)
    - Article 3393 - Disc Brake Lining Wear - (F-250-350 Trucks with Front Disc Brakes - 1968-71)
    - Article 3394 - Steering Gear Replacement - Pinto - 1971)
    - Article 3395 - Driving Axles - Limited Slip Models 44-1F(J) and 60 (B4, B5, C1, C3, C5, C7, C8) - Disassembly and Assembly - (Bronco, E-300, F250-350 and P-350 with Warranty Plate Axle Codes Indicated in Parenthsis Above)
    - Article 3396 - Oil Pump Assembly - New - (Pinto with 1600cc Engine - 1971)
    - Article 3397 - Camshaft Drive Belt Jumping Timing - (Pinto - 2000cc Engine - 1971)
    - Article 3398 - Timing Belt Tensioner - (Pinto with 2000cc Engine - 1971)
    - Article 3399 - Oil Pan Bolt Torque Sequence - 2000cc Engine - (Pinto - 1971)
    - Article 3400 - Thermactor Exhaust Emission Control System - (330 MD and HD Truck Engines - 1971)
    - Article 3401 - Decel Valve - Replacement - (Pinto with 1600cc Engine - 1971)
    - Article 3402 - Engine Front Thermostat Damage - (C & L Series Trucks Equipped with Super Duty Engines and Engine Temperature Warning Systems)
    - Article 3403 - Spark Plugs - Cleaning and Replacement - (Pinto - 1971)
    - Article 3404 - Turn and Embergency Signal Switch - Improved - (All Medium, Heavy and Extra-Heavy Trucks with Steering Column Hub-Mounted Switch - 1967-71)
    - Article 3405 - AM/FM Multiplex Radio - Delayed or Intermittent Channel Operation - (Ford - 1971)
    - Article 3406 - Rattle or Vibration Noise Under Dash - Light Truck - SUPERSEDES ARTICLE NO. 3365, TSB NO. 161 - (F100/350 - 1971)
    - Article 3407 - Door Glass Breakage During Slam - (Pinto - All Models - 1971)
    - Article 3408 - Tailgate Window Washer/Wiper Operation Improvement (SUPERSEDES ARTICLE 3362, BULLETIN 161, DATED 3/12/71. PART NUMBER CORRECTION) - (Ford Station Wagon Equipped with Rear Window Washer - 1971)
    - Article 3409 - Windshield Stress Cracks - (Ford - All Models - 1971)
    - Article 3410 - Windnoise at the "A" Pillar Belt Area - (All Car Lines - All Models - 1971)
    - Article 3411 - Luggage Compartment Door Hinge Adjustment - (Pinto Model 64B - 1971½)
    - Article 3412 - Bumpers - Protective Wax Removal - (All Passenger Cars)
    - Article 3413- Shoulder Belt Connector Grommet Replacement - (All Car Lines - 1971)
cron
