- - Article 3414 - Power Steering Pump Reservoir - Repair - ("F" & "B" Series 6000-7000 Trucks with Caterpillar V-8 Engines)
- Article 3415 - Front End Alignment Specifications - (Econoline and F-100-350 [4x2] - 1971)
- Article 3416 - Axle Housing Leaking Dana - All Units - (All Ford Trucks and Broncos)
- Article 3417 - Clutch Pedal Adjustment Procedure - F100-F350 Trucks - (F-100-350 Trucks - 197071)
- Article 3418 - Automatic Transmission - Binding Main Oil Pressure Booster Valve - THIS ARTICLE SUPERSEDES TSB 156, ARTICLE 3224, DATED 12-8-70 - (All with C4 or C6 - 1967 through 1971)
- Article 3419 - Initial Ignition Timing Revision - THIS ARTICLE SUPERSEDES ARTICLE 3374, TSB 162 - (Pinto - 2000cc Engine - 1971)
- Article 3420 - BF-42 Spark Plug Replaces BTF-31 Spark Plug - 302 CID - Light Truck - Econoline - (F100, E100/300 - 1971)
- Article 3421 - Radiator Tanks, Upper and Lower - Stainless Steel - (L-9000 and "W" Series with NH, 6-71, NTC or 8V71)
- Article 3422 - Back-Up light Switch - Plunger Damaged - (Pinto Equipped with Ford of Germany Design Manual Transmission - 1971)
- Article 3423 - Fuel Gauge - Inoperative - (Mustang, Maverick Pinto - All Models - 1971)
- Article 3424 - Front End Sheet Metal Reinforcemetns - SUPERSEDES ARTICLE 2945, TSB 144 - (School Bus - Models B500-B750 - 1967-70)
