January 1971 - December 1971
Bulletin No. 166 - June 4, 1971
(15 articles)
  • Article 3447 - Brake Diagnostic Information - (All Passenger Cars - 1970-71)
  • Article 3448 - Power Steering Moan and Chatter Noise During Static Turns - (Mustang Cars with 240, 302, or 351 CID Engines -1971)
  • Article 3449 - New Pistons for FT Engines - (361 and 391 CID - 1971)
  • Article 3450 - New Fuel Pump Assembly (2000cc Pinto Engine - 1971)
  • Article 3451 - Thermostat Controlled Water By-Pass System - (361 and 391 CID Truck Engines - 1971)
  • Article 3452 - Power Window Multiple Switch Button Assembly and Boot Removal and Replacement - (Ford - All Models Equipped with Power Windows - 1971)
  • Article 3453 - Battery Discharged - (Vehicles Equipped with 61 Ampere Alternator - 1971)
  • Article 3454 - Turn Signal Switch - Diagnostic Tip - (All Models)
  • Article 3455 - Changes in Operational Modes - (All Vehicles So Equipped - 1971)
  • Article 3456 - Ignition Switch and Wiring Connector Replacement - (All Passenger Cars - 1969)
  • Article 3457 - Wiring Repairs - Fuse Panel Area - (Mustang - All Models - 1971)
  • Article 3458 - Wiring Harness - Fuse Link - Replacement - (All Car Lines - 1971)
  • Article 3459 - Adding Teflon Tape to water or Oil Sender/Switch Threads - (All Engines)
  • Article 3460 - Trailer Towing Package - Installation - (Ford - All Models - 1971)
  • Article 3461 - Exterior Wax Removal Procedure - (Torino - Limited Production - Lorain and Atlanta Built Units - 1971)
cron
