January 1971 - December 1971
Bulletin No. 170 - July 16, 1971 [COMPLETE]
(7 articles)
  • Article 3290 - Installing Tools - Front Wheel Seals
    (Truck)
  • Article 3291 - Parking Brake Cable Tension Adjustment
    (F-100-350, P-350, E-100-300 and Bronco)
  • Article 3292 - Steering Wheel/Column Squeak
    SUPERSEDES ARTICLE 3462, TSB 167, DATED JUNE 18, 1971)
    (E100-200-300 Econoline - 1971)
  • Article 3293 - Production Revision - 2000cc Engine Spark Plug, Air Cleaner and Carburetor Changes
    (Pinto - 2000cc - 1971)
  • Article 3294 - Back-up Light Switch Damaged
    (Pinto - Equipped with Ford of Germany Design Manual Transmission - 1971)
  • Article 3295 - Turn Signal Switch Cancel Cam Replacement
    (All Car Lines - 1970-71)
  • Article 3296 - Adapter for Upper Arm Lube
cron
