January 1972 - December 1972
Bulletin No. 09 - January 14, 1972 [COMPLETE]
(11 articles)
  • Article 78-S [SUPPLEMENT] - Water Entry into Front Passenger Compartment (Part Number Change) - (1971-72 Pinto)
  • Article 93 - Front Bumper Lower Stone Deflector - Rattles - (1972 Mark IV)
  • Article 94 - Seat Back Will Not Always Unlatch - Automatic Release - (1972 Torino/Montego, Thunderbird/Mark IV)
  • Article 95 - Disc Brake Squeal - (Capri - All Models Built Prior to August 1971)
  • Article 96 - Automatic Temperature Control - Unsatisfactory Operation - (1972 Thunderbird/Mark IV)
  • Article 97 - Improper "Dome" Lamp or "Dome-Map" Lamp Light Leakage - (1972 Thunderbird and Torino [R.P.O.]; 1972 Mark IV [standard] and Montego [R.P.O.])
  • Article 73-S [SUPPLEMENT] - Shift Lever Noise - Standard Transmission - (1969-71 Ford - All Car Lines and 1972 Maverick - with Column-Mounted Shift Lever; 1969-71 Lincoln-Mercury - All Car Lines and 1972 Comet - with Column-Mounted Shift Lever)
  • Article 98 - Camshaft Drive Belts Jumps Timing - (1971 Pinto/Capri with 2000cc Engines)
  • Article 99 - Delayed or Erratic Shifts - (1971-72 F, B, C, and LN 600-750 and C 800 Trucks with Allison AT-540 Automatic Transmission)
  • Article 100 - Engine - Water Entry Through Vertical Exhaust - (1970-71-72 W-WT Trucks with Cummins V-903 - Detroit 8V-71 Engines)
  • Article 101 - Excessive Engine Oil Consumption - (1970-71 401, 477, 534 CID Truck Engines with Dry Type Air Cleaners)
