January 1972 - December 1972
Bulletin No. 28 - November 3, 1972
(13 articles)
  • Article 254 - Front and Rear Bumper Stone Deflector Paint Repair - (1973 All Car Lines)
  • Article 255 - Rear Seat Back latch Area - Squeaks - (1972 Pinto Model 73)
  • Article 256 - Extra Length Service Seat Belts - (1972 All Car Lines)
  • Article 257 - Quarter Flipper Window - Loose - (1972½ Pinto Station Wagon)
  • Article 258 - Automatic Temperature Control System - Erratic Operation - (1973 Ford/Mercury)
  • Article 259 - Speed Control Inoperative After Turn Signal Switch Replacement - (All Vehicles Equipped with Speed Control)
  • Article 260 - Insufficient Heat - (1972 Pinto - Standard Heater without A/C)
  • Article 261 - Modified Heating and Ventilation - (1971-72 Capri Equipped with 2000cc or 2600cc Engines)
  • Article 262 - Insufficient Heat - (1973 Ford/Mercury without A/C)
  • Article 263 - Front Wheel Shimmy - (All Capri)
  • Article 264 - Kinked Vacuum Hose at Distributor - (All 1972 400 CID Engines Equipped with Dual Diaphragm Distributor and A/C Only)
  • Article 265 - Delayed Shifts and/or Shift Pile-Up - (1972 Ford/Mercury - Mustang - P350-400-500 - F350 Trucks with FMX Automatic Transmission)
  • Article 266 - Drive Line "Ring" - (1972 and Prior F-100 4x4 with Dana model 21 Transfer Case)
WEBMASTER'S NOTE: This TSB #28 includes an Article 266...but the next TSB (#29, dated 11/17/72) also contains an Article 266, neither of which are related or even similar.
