January 1972 - December 1972
Bulletin No. 29 - November 17, 1972
(13 articles)
  • Article 266 - Center Body Pillar Inside Upper Finish Panel - Loose - (1973 Ford/Mercury Models 53, 71)
  • Article 267 - Liftgate Difficult to Open - (1972 Pinto Model 73B)
  • Article 268 - Door Trim Panel Retention - (1973 Ford/Mercury All Models)
  • Article 269 - Power Door Lock - Unlock Relay Malfunction Diagnosis Procedure - (1973 Ford/Lincoln/Mercury All Four Doors and Station Wagons)
  • Article 270 - "Whistle" Noise From A.T.C. Aspirator - (1972 Thunderbird with Automatic Temperature Control)
  • Article 271 - Rear Axle Lubricant Leakage at the Sure-Track Mounting Bracket - (1973 Thunderbird/Lincoln/Mark IV with Sure-Track Brake System)
  • Article 272 - Exhaust Resonance - (1971-72 Capri)
  • Article 273 - Inoperative or Erratic Fuel Gauge - (1973 F-350 Model Trucks with 140" Wheelbase)
WEBMASTER'S NOTE: This TSB #29 includes an Article 266...but the previous TSB (#28, dated 11/03/72) also contains an Article 266, neither of which are related or even similar.
