January 1966 - December 1966
Bulletin No. 51 - November 18, 1966 [COMPLETE]
(14 articles)
  • Article 942 - Headlamp Adjusting Screw Tabs Bending or Breaking
    (1966-67 All Trucks, Thunderbird)
  • Article 943 - New Spark Plugs
    (All 1967 Trucks)
  • Article 944 - Water Entry in Marker Lamps
    (1966 Truck - All Models)
  • Article 945 - Excessive Accelerator Pedal Effort or Insufficient Open Throttle
    (1966-67 Econoline with 240 CID Engines)
  • Article 946 - Steering Shaft Upper U-Joint Maintenance
    (1966½ W Series)
  • Article 947 - Dana Rear Axle Cover Leaks
    (F-100/350; P350/400; P3500/4000)
  • Article 948 - Gear Jump-Out 5th & 10th Speeds - Fuller RT-910 Transmission
    (Heavy and Extra-Heavy Trucks)
  • Article 949 - Oil in Speedometer or Tachometer Head
    (1966 and Prior Model "N" "H", and "W" Series Trucks with Fuller RT-910 Transmissions)
  • Article 950 - C6 Transmission
    (All Models)
  • Article 951 - Stop Light Switch Installation Procedures
    (1967 F-100/350)
  • Article 952 - Cab Air Vents - Sticking or Binding
    (1967 F-100 thru F-350)
  • Article 953 - Clicking Noise in Radio
    (1967 Light and Medium Trucks with Factory Installed Radios)
  • Article 954 - Front Door - Sheet Metal Fatigue Cracks at the Belt
    (1961-1966 Econolines)
  • Article 955 - Front Spring Replacement
    (All 1965 through 1967 Ford Models and All 1967 Thunderbirds)
cron
