January 1966 - December 1966
Bulletin No. 45 - September 2, 1966
(19 articles)
  • Article 889 - Accelerator Linkage - Binding, Lack of wide Open Throttle, or Accelerator Pedal Shaft Unscrews - (1966-½ "W" Series)
  • Article 890 - Improved Brake Treadle Position - (1965-66 B600-750 and F600-750 [Model 74] with Air Brakes
  • Article 891 - Valve Stem Tip Wear Problem - (1965-1966 240 CID Truck Engines)
  • Article 892 - Front Engine Mount Installation - (H-1000-D, HT-950-D, N-850-1100-D, NT-850-950-D Trucks with Cummins NH Diesel Engines)
  • Article 893 - Drive Shaft and Universal Joint Maintenance - (Medium, Heavy and Extra Heavy Trucks)
  • Article 894 - Inadequate Camper Special Mirrors Used on Units with 90" or Wider Campers - (All 1965-1966 Camper Special Vehicles)
  • Article 895 - Inoperative or Erratic Horn - (All 1966 and Prior medium and Heavy Trucks except N, P or W Series)
  • Article 896 - Use of Automatic Transmission and Power Steering Fluid Meeting Ford Motor Company Specification M2C33D - (All Automatic Transmission and/or Power Steering Equipped Vehicles)
  • Article 897 - Revised Connecting Rod Assembly - (All 221, 260 and 289 C.I.D. Engines)
  • Article 898 - Gear Rattle - 4 Speed Warner Transmission - (1965-6 F-100-250 P-3500-5000)
  • Article 899 - Clutch Pressure Plate Cover Assembly to Flywheel Bolt Torque Specification - (1965-1966 Passenger Cars with Standard Transmissions)
  • Article 900 - "Scrubby" Clutch Pedal Condition and/or High Pedal Effort - (1965-1966 Ford, Fairlane, Falcon, and Mustang Vehicles with Manual Transmission)
  • Article 901 - Fumes in Passenger Compartment - (1966 Fairlane Station Wagons, 1965 Ford Station Wagons)
  • Article 902 - Potential Heater Core Damage - (1966 Truck - Models F250 4x4, F350-750, B500-750)
  • Article 903 - Identification and Installation of Reusable Swivel Hose Ends - (1966½ "W" Series Trucks)
  • Article 904 - New Exhaust Manifold - 1965-1966 300 CID Heavy Duty Engine - Truck)
  • Article 905 - Air Brake Reservoir Check Valve Leaks - (All Trucks with Air Brakes)
  • Article 906 - Brake Squeal - (All Medium Trucks with 16 x 2½ Front and 16½ x 4½ rear "S" Cam Operated Brakes)
  • Article 907 - Lower Radiator Hose Support Bracket - (Caterpillar Engine Equipped Trucks)
cron
