January 1966 - December 1966
Bulletin No. 44 - August 19, 1966
(18 articles)
  • Article 838 - Excessive Oil Consumption - Correction of Article 838, TSB #41 Dated July 1, 1966 - (All 1966 289 CID Engined Identified as Change Level 10 on the Engine Identification Tag and Built Prior to April 1, 1966)
  • Article 872 - Bench Type Front seat Cushion Roll-Off - (1966 Fairlane and Falcon)
  • Article 873 - Front Spring Shackle Attaching Bolts - (1963-1966 F-B-N-500-750 Trucks)
  • Article 874 - Underbody Failures - Poor Welds and Metal Fractures at Rear Cross Center Outer Member Assembly - (1966 Econoline - All Models)
  • Article 875 - Idler Arm Shaft Looseness - (1965-66 H-1000, H-1000D, HT-950 and HT-950D)
  • Article 876 - Windshield Wiper Linkage - (1965-66 Truck - All Conventional cab and COE)
  • Article 877 - Exhaust Inlet Pipe Flexible Mount - ("W" Series Trucks)
  • Article 878 - Glove Compartment Door "Pop Open" - (1966 Econoline - All Models with Padded Instrument Panel)
  • Article 879 - Scrubby Feel in Steering Wheel, Noise and High Steering Efforts - (1966 Ford, Fairlane, Falcon with Power Steering)
  • Article 880 - Loosening of Door Latch Attaching Screws - (1966 Bronco - All Models)
  • Article 881 - Radius Arm Insulator Replacement - (1966 F-100 4x4 and 4-100)
  • Article 882 - Reversible Keys - (1967 Vehicles)
  • Article 883 - Ignition Switch Continuity Check - (All 1965 and 1966 Car Lines)
  • Article 884 - Mid-Range Cummins Fan Failure - (C-8000 Trucks with CF 160 and CF 180 Cummins Engines)
  • Article 885 - Potential Damage to Instrument Panel Wiring - (1966 Falcon - All Models)
  • Article 886 - Erratic or High Reading of Instrument Cluster Gauges - (Mustang, Thunderbird, all Trucks except Econoline & Tiltcab models)
  • Article 887 - Speedometer cable Attaching Clip - (1966½ "W" Series with RT910, RTO-990, T-905 and T-905-B Transmissions)
  • Article 888 - Short Deluxe Front Seat Belt and Buckle Assembly - (1966 Fairlane and Falcon - All Models with Deluxe Belts)
