January 1966 - December 1966
Bulletin No. 42 - July 15, 1966
(18 articles)
  • Article 548 and 735 - CORRECTION OF WARRANTY STATUS COMMENT - Articles 548 & 735 - (All 1965 Car and Truck - All 1966 Econoline and Parcel Series
  • Article 765 - CORRECTION TO ARTICLE #765 DATED MAY 6, 1966 - OIL CONSUMPTION - (All 330, 352, 361, 390, 427, 428 Passenger Car and Truck Engines)
  • Article 845 - Ford Model 4300 4V Carburetor - (1966 Ford Galaxie cars with 428 C.I.D. engine - except Police Interceptor and Thermactor Equipped Engines)
  • Article 846 - 391 CID Conversion Kits - (1962-64 F-750, 800 with 332 CID Engines)
  • Article 847 - New Rear Brake Drum - (1966 T-950 with 50,000-60,000 Pound Rockwell Tandem Axles, F-950 with 29,000 Pound Rockwell Rear Axle and 16½ x 7 Rear Brakes)
  • Article 848 - Lubricant - Transmission Shift Linkage - (C, W & H Series Trucks)
  • Article 849 - Noise in Second Gear and/or Second Gear Jump-Out - (All 1966 Passenger Cars and Trucks Equipped with Three Speed (3.03) Constant Mesh Transmissions)
  • Article 850 - "W" Series Radiator Installation - (1966 "W" Series Trucks)
  • Article 851 - Tailgate Hinge bind and/or Chatter - (All 1966 Station Wagons Equipped with Dual-Action Tailgates)
  • Article 852 - Bench Type Front Seat Sag - Helper Spring Modification (Revision to Technical Service Bulletin #272, Dated April 19, 1965 - (1965-66 Ford - All Models)
  • Article 825 - *Delco Remy Starter for Dagenham Diesel Trucks - (1962-1966 N, C & P Series with CAV Starter)
  • Article 853 - Windshield Wiper Lock-up - (1966 Bronco - All Models)
  • Article 854 - Damaged or Inoperative Fuel Gauge - (1965-1966 Mustang - All with Fog Lamps)
  • Article 855 - Horn Malfunction - (1965-66 "C" Series Truck)
  • Article 856 - Hard Shifting Complaints - New Process 4-Speed Transmissions - (Light Trucks)
  • Article 857 - Brake Squeal - (All Medium and Heavy Trucks with 16 x 2½" Front and 16½ x 4½" Rear "S" Cam Operated Air Brakes)
  • Article 858 - Steering Shaft and Coupling Shaft Clamp Bolts Loosening - (1966 F-100 4x4 and Bronco)
  • Article 859 - Steering Wander - (1966 "N" Series Trucks with Super Duty or Diesel Engines)
* This article was omitted from the previous TSB #41 and was subsequently printed in this issue between Articles 852 and 853.
