January 1966 - December 1966
Bulletin No. 41 - July 1, 1966
(28 articles)
  • Article 757 - Article 757 Correction - Universal Joint Lubrication - (Trucks)
  • Article 817 - Vacuum Pump Spline Wear - (All Dagenham 220 and 330 CID Equipped with Vacuum Pump)
  • Article 818 - Restricted Right Turn - (1966 C-550 - 750 and C-6000 - 7000 Trucks with Manual Steering)
  • Article 819 - Clark 5-Speed Transmission 250 and 265 Series - (1964-6 Medium and Heavy Trucks)
  • Article 820 - New Master Cylinder - )193-66 F B & N - 500-700 and F-350 with Cowl Mounted Brake Booster
  • Article 821 - Thermactor Air Pump Relief Valve Silencer - (1966-1970 170 and 200 C.I.D. Falcon Engine - 1966 200 C.I.D. Mustang, Comet and Fairlane Engine)
  • Article 822 - Dagenham Fuel Line Connector - (All Dagenham Diesels with Fuel De-aeration)
  • Article 823 - Mid Range Cummins Surge Tank - (All C-8000 with CF 160 or CF 180 Cummins Engine)
  • Article 824 - Air Compressor Support Bracket - (330-361-391 CID Truck Engines)
  • Article 825 - (See Note 1)
  • Article 826 - Fuel Solenoid Mounting Bracket - (1964, 65, 66 C-7000 Trucks with 6 Cylinder Dagenham Diesel)
  • Article 827 - Floor Pan Sheet Metal Fractures - (1961 thru 1966 School Bus - Model B-500-750)
  • Article 828 - Excessive Heat Emanating From the Front Seat Belt Floor Attaching Plate and Bolts - (1966 Ford - All Models)
  • Article 829 - Accelerator linkage - Pedal Freeplay and/or An Inability to Obtain Full Throttle - (1966 Fairlane Units Equipped with the 390-4V or 390-4V (GT) Engine)
  • Article 830 - Exhaust Boom at 20/40 MPH - 1966 Falcon Sedan - (Model 54 & 62 with Six Cylinder Engines and Automatic Transmissions)
  • Article 831 - Clock Malfunction - (1966 Ford and Fairlane)
  • Article 832 - Steering Problems - (1966 C and CT Series Trucks)
  • Article 833 - Hard Hot Starts and/or Stall After Hot Starts - (1965 and 1966 352-4V Equipped Units)
  • Article 834 - Operating Notes on the Rotunda Alternator System Tester - (All Vehicles 1963-Later)
  • Article 835 - Muffler Outlet Pipes - (All 1965 Ford Station Wagon)
  • Article 836 - Ignition System Problem Diagnosis - (All)
  • Article 837 - Fuel System Information - (1966 Passenger Cars)
  • Article 838 - Excessive Oil Consumption - (All 1966 289 CID Engines Identified as Change Level 10 on the Engine Identification Tag and Built Before April, 1966)
  • Article 839 - Substitution of Horn Button for Horn Ring - (1966 Fairlane Models 62A and 54A)
  • Article 840 - Heavy Duty Front Seat Cushion Assembly Identification - (1966 Ford - All Models with Bench Seat)
  • Article 841 - Water Leak - Cowl Top to Cowl Side Panel Joints - (1965-1966 Mustang and 1966 Falcon and Fairlane - All Models)
  • Article 842 - Low and Reverse Gear Synchronizer to Output Shaft Installation and Removal - (All 1966 Ford Design Three and Four Speed Manual Transmission - Passenger Car and Truck)
  • Article 843 - Window Motor Thrust Screw Adjustment - (All Vehicles with Power Windows)
  • Article 844 - High Shift Efforts and/or Binding Transmission Shift Linkage - (1966 Falcon, Fairlane and Mustang with Floor Mounted Standard Transmission, 3 and 4 Speed)
Note 1: This article was omitted from this TSB but printed in the following TSB # 42.
cron
