January 1966 - December 1966
Bulletin No. 40 - June 3, 1966
(17 articles)
  • Article 799 Additional Service Information Rockwell SLHD Tandem Axle - (1965-66 Trucks Equipped with Rockwell SLHD Tandem Axle)
  • Article 800 - Rocker Valve Cover Oil Leaks at Plugs - (1966 - 390 Fairlane "GT")
  • Article 801 - Ignition Timing Specifications - (All 1966 Vehicles)
  • Article 802 - 240 CID Piston Noise - (All 1965-1966 240 CID Engines)
  • Article 803 - Short Deluxe Front Seat Belt and Buckle Assembly - (1966 Fairlane and Falcon - All Models with Deluxe Seat Belts)
  • Article 804 - Delco Starter Yoke Pivot Pin Loss - (All Trucks with Cummins Mid Range [160-180] Diesel Engine)
  • Article 805 - Hood Hinge Failures - (1964-1966 School Bus B-500-750)
  • Article 806 - Engine Change Level Identification - (All Engines)
  • Article 807 - Tailgate Door Opens with Glass in Raised Position - (1966 Ford - Model 71)
  • Article 808 - Noisy and/or Squeaking valve Rocker Arms and Valve Stem Length Specifications - (1965-1966 240, 289, 300 CID Engines)
  • Article 809 - Clark 305-V and 307 V Extra Heavy Duty Transmissions - (1966 Ford Trucks Series 750, 800, 850, 950)
  • Article 810 - Noise and Vibration Diagnosis - (1965-6 F-100-350 Trucks with 4 Speed New Process Transmissions)
  • Article 811 - Inability to Adjust Clutch Free Play to Specification and/or False Free Play After Adjustment - (1966 Falcon and Fairlane with Standard Transmission)
  • Article 812 - Oversize Production Repair Bushings for Exhaust Control Valve Shaft Assembly - (1965, 1966 240 and 300 CID Car and Truck Engines)
  • Article 813 - Piston Changes - (1966 289 V-8 Engines - Except High Performance)
  • Article 814 - Automatic Transmission Overrunning Clutch Inner Race - (All 1966 C4 Three Speed Automatic Transmissions)
  • *Article 815 - Rear Seat Cushion Retention - (1966 Ford, All Models)
*WEBMASTER'S NOTE: This article is numbered identically to the only article in TSB No. 41 Supplement (dated June 24, 1966) which discusses Fairlane 390 GT and GTA specifications. Though the two articles are numbered the same, they are unrelated, and the similarly-numbered articles are presumably a simple typographical error.
cron
