January 1966 - December 1966
Bulletin No. 39 - May 20, 1966
(12 articles)
  • Article 787 - 289 V-8 Engine - (1966½ Bronco)
  • Article 788 - New Process Five-Speed Transmission - Models NP-541FD and NP-541FO - (F-B-500-600 Series Trucks)
  • Article 789 - Alternator Regulator Test Procedure Revision - (All Car Lines - All Models)
  • Article 790 - Installation Problem, Air Conditioning Unit, C6ZZ-19700-B - (1966 Mustang September-October Built, 289 Engine)
  • Article 791 - Revised Starter Ring Gear - (1965
  • Article 792 - Erratic Operation, Door Ajar Warning Light - (1966 Thunderbird 2 Door Hardtop and Landau)
  • Article 793 - Valve Train Changes - (1966 289 V-8 Engines Except High Performance)
  • Article 794 - Thunderbird Speed Control Holding Relay Replacement - (1966 Thunderbird So Equipped)
  • Article 795 - Steering Shaft and Coupling Shaft Clamp Bolt Loosening - (1966 F-100 4x4 and Bronco)
  • Article 796 - Servicing Starting Motors with Needle Bearings - (All Ford and Thunderbird 428 CID Engines)
  • Article 797 - Crankshaft Thrust Bearing Failures - (1965 Model Year Trucks with 300, 330, 361, and 391 CID Engines)
  • Article 798 - Passenger and Luggage Compartment Water Leaks - (1966 Thunderbird - All Models)
cron
