January 1966 - December 1966
Bulletin No. 38 - May 6, 1966
(23 articles)
  • Article 764 - Vehicle Bounce - (1965-66 F-100-350 and P-350-400)
  • Article 765 - Oil Consumption - (All 330, 352, 361, 390, 391, 410, 427, 428 Passenger Car and Truck Engines)
  • Article 766 - Convertible Top and Deck Lid Cycling Malfunction - (1966 Thunderbird - Model 76A)
  • Article 767 - Possible Damage to Cigar Lighter and/or Emergency Warning Flasher Wiring - (1966 Ford - All Models Built Before April 1, 1966)
  • Article 768 - Rear Axle Shaft Stud Failures - (1963-65 F, B, N-500/600, B-700, T-700 and C-550/600 with Disc Wheels)
  • Article 769 - Inoperative Windshield Washer System - (All Cars and Trucks)
  • Article 770 - 1966 Heavy Truck Odometer - (All)
  • Article 771 - Emergency Warning Flasher Fuse Blown - (All 1965-66 Trucks wit Tractor Package)
  • Article 772 - Supplement and revision to Article 596 Aluminum Sleeper Compartment Failure - (1965 H Series with 32"Aluminum Sleeper Cab)
  • Article 773 - Premature Rear Brake Drum Wear - (All 1965-66 Heavy and Extra Heavy Trucks with 16½" x 6" and 16½" x 7" "S" Cam Air Brakes)
  • Article 774 - Steering Gear Lubricant Leaks - (1966 Bronco)
  • Article 775 - Valve Spring Changes - (1966 289 V-8 Engines Except High Performance)
  • Article 776 - Addition to Article #620 Dealer Replacement of Front hub and Drum Assemblies - (1966 Falcon Ranchero, Falcon 8-Cylinder Station wagon, and 289 CID 8-Cylinder Engines Fairlane Station Wagon)
  • Article 777 - Rear Brake Shoe Retaining Spring Failures - (All Trucks with "S" Cam Operated Eaton Design Air Brakes)
  • Article 778 - Steering Shaft and Coupling Shaft Clamp Bolts - (1966 F-100 4x4 and Bronco)
  • Article 779 - Power Steering Pump Pressure Line Fitting Leaks - (1963-65 Extra Heavy Trucks with 401-477 or 534 CID Engines)
  • Article 780 - Water Leaks at Liftgate Weatherstrip and Top of Tailgate - (1966 Bronco - Model 98)
  • Article 781 - Portable Tool Board Stand
  • Article 782 - Test Procedure - Thermactor Backfire Suppressor Valve - (All Thermactor Equipped Vehicles)
  • Article 783 - Single Leaf Auxiliary Rear Spring - (1966 F-350)
  • Article 784 - Transmission - Hard Shifting Into First and Reverse Gears - (1965 C & H Series with 5000-6000 Spicer Transmissions)
  • Article 785 - New Spring Assembly - (All Hendrickson Steel Leaf Tandem Suspension with 38 and 44,000# Capacity Rear Axles)
  • Article 786 - Dagenham Air Compressor Mounting Failure - (C & N Series Vehicles Equipped w/Air Compressors and Dagenham Engines)
cron
