January 1966 - December 1966
Bulletin No. 37 - April 22, 1966
(20 articles)
  • Article 744 - New Rocker Arm Cover Gasket - (All 240-300 CID Passenger Car and Truck Engines)
  • Article 745 - Canadian and U.S. Drive Shaft Interchangeability - (Canadian built Medium Duty Trucks)
  • Article 746 - Front Tire Interference on Full Turns - (1965-1966 Thunderbirds)
  • Article 747 - Econoline Shimmy - (Information Only) - (1964-1965 E-100)
  • Article 748 - New Tappet Assembly and Collapsed Tappet Clearance Specification Revisions - (All 390, 410, 428 [Except Police Interceptor] Engines)
  • Article 749 - Front Disc Brake Caliper to Spindle Attaching Bolt - (All 1965-1966 Thunderbird)
  • Article 750 - Maxibrake Repairs - (Heavy Trucks Equipped with Maxibrake Air Parking Brake)
  • Article 751 - Front Brake Hose Retaining Strap Breakage - (All 1966 Fords with Disc Brakes Only)
  • Article 752 - Transistor Ignition System Servicing Procedures - (All Vehicles with Transistorized Ignition)
  • Article 753 - Headlamp Bulb Failures Due to Road Splash - (All 1966 Fairlane - All Models)
  • Article 754 - Disc Brake Master Cylinder Reservoir Cover Seal Diaphragm - (All Vehicles with Disc Brakes - Thunderbird, Ford, Mustang)
  • Article 755 - Erratic Shifts Caused by Improperly Installed Engine to Transmission Vacuum Tube - (All 1966 Vehicles with Automatic Transmission)
  • Article 756 - Broken Stowage Compartment Door Lock Handles - (1961-1966 H Series)
  • Article 757 - Universal Joint Lubrication - (HT-950-D, NT-950-D, and N-1000-D Trucks)
  • Article 758 - Engine Housing Heat Insulation - (1966 Econolines Equipped with Thermactor)
  • Article 759 - Vickers Power Steering Pump - (1966 W-Series Trucks)
  • Article 760 - Front Axle Spindle Bushing Kit Part C2TZ-3111-A - (1961-66 Medium Trucks with 6000# Axle)
  • Article 761 - Front Spring Jumpout - (1965 F-100/250 Trucks)
  • Article 762 - Ammeter, Constant Voltage Regulator and Temperature Gauge Failures - (1966 Mustang, All Models)
  • Article 763 - Accelerated Corrosion of the Front Center Body Panel Due to Water Entrapped by the Front Body Crash Bar Weatherstrip - (1961-66 HT Series Trucks)
cron
