January 1966 - December 1966
Bulletin No. 36 - April 8, 1966
(14 articles)
  • Article 730 - Single-Speed Transfer Case - (F-100 Trucks with Four-Wheel Drive)
  • Article 731 - "C" Series Multiple Plug Disconnects When Cab is Tilted - (ALl 1961-66 "C" Series Trucks)
  • Article 732 - 2-Piece Semi-Drop Center Wheel with Slide Ring - (Light Trucks)
  • Article 733 - 352-2V CID Oil Consumption - (Light Trucks with 352-2V CID Engines)
  • Article 734 - Service Refinishing of Disc Brake Rotors - (Ford, Mercury, Mustang, Thunderbird, Lincoln)
  • Article 735 - Correction to Article 548 - Hard Hot Starting 240 CID Econoline - (All 1965 and 66 Econoline and Parcel Series)
  • Article 736 - Inadequate Illumination of the Cruise-O-Matic Quadrant Indicator - (1966 Ford Equipped with Steering Column Mounted Cruise-O-Matic P-R-N-D-L Dial)
  • Article 737 - Parking Lamp Water Leaks - (1966 Ford - All Models Except XL-LTD and Country Squire)
  • Article 738 - Potential Damage to Instrument Panel Wiring in Back of Ignition Switch - (1966 Thunderbirds - Built Prior to December 21, 1965)
  • Article 739 - Windshield Wiper Noise - Two-Speed Oscillating Wiper Motor - (All 1965-1966 Vehicles Equipped With a Two-Speed Oscillating Wiper Motor)
  • Article 740 - Brake Fluid Leakage at te Master Cylinder Reservoir Cover - (1963-66 F-600/700 and N-600/700 with Cowl Mounted Brake Booster)
  • Article 741 - Fluid Loss at the Transmission Breather Tube - (All C4 Three Speed Transmissions)
  • Article 742 - Engine Harshness and/or Rough Idle - 1966 Mustang - (All Models with 6-Cylinder Engines)
  • Article 743 - Loose Rear Lower Shock Attachment - (1965 Ford - All Models; 1966 Ford - All Models Built Prior to November 22, 1965)
cron
