January 1966 - December 1966
Bulletin No. 35 - April 1, 1966
(28 articles)
  • Article 702 - Correction of Part Number for TSB #678 - Loss of Power Assist on Power Brake Vehicles - (All 1965 Thunderbird Models with No Speed Control)
  • Article 703 - Six-Way Power Bucket Seat Chucking - (1966 Thunderbird)
  • Article 704 - Trim Cement Removal - (All Car Lines)
  • Article 705 - Wheel Shimmy and/or Premature Failure of Power Steering Cylinder Bushings - (1963 N-850/1000; NT-850/950; C-850-1000 and CT-750/950)
  • Article 706 - Flywheel and Starter Failures - (1964-66, 361, 391 CID Engines with Transmatic Transmissions)
  • Article 707 - New Piston and Pin Assembly - (1965 and 1966 352 CID Car and Truck Engine)
  • Article 708 - Installation of Automatic Transmission Output Shaft Oil Seal - (All 1960-1966 Vehicles Equipped with Cast Iron Case Cruise-O-Matic Transmissions)
  • Article 709 - Revised Torque Specifications - Bronco Transfer Case - (1966 Bronco - All)
  • Article 710 - 12 Volt Delco Starter Replacement - (W-Series Truck)
  • Article 711 - Pedal Shaft Leaks at the Accelerator - (1965 Econoline)
  • Article 712 - Premature Drag Link Wear - (F-100/250 4x4; F-350; P350/500 and P-3500/5000 Trucks)
  • Article 713 - Erratic Starter Action or Loss of Ignition - (All Cars and Trucks)
  • Article 714 - Canadian and U.S. Drive Shaft Interchangeability - (Canadian Built Medium Duty Trucks)
  • Article 715 - Oil Dipstick Identification (All 1966 Passenger and Truck Engines)
  • Article 716 - Distributors - (1966 Trucks with 361 V-8)
  • Article 717 - MX Automatic Transmission Manual Control Lever Assembly - (1965 F-350, P-350, P-400 and P-500 Trucks)
  • Article 718 - Relocation of the Exhaust System Indexing tabs on 1966 Fairlane - (All with 390-4V Engines except Station Wagons and Convertibles)
  • Article 719 - Carburetor Heater Hose Failures - (All Econolines and Broncos with 170 CID Engine and Thermactor)
  • Article 720 - Front Brake Contamination - (1963-65 F, B, N500/750 and N-6000/7000 with Cast Spoke Wheels and 5000 or 5500 Pound Front Axles)
  • Article 721 - Torque Loss - Cab Rear Support to Frame - (All "N" Series Trucks)
  • Article 722 - "A" Pillar and Windshield Area Water Leaks - (1966 Fairlane and Falcon - All Models)
  • Article 723 - High Operating Efforts of the Gear Selector Lever - (1966 Thunderbird with C6 Dual Range Automatic Transmissions)
  • Article 724 - New Exhaust Valves - (Super Duty Engines - 401-477-534)
  • Article 725 - Unsightly Appearance Along Headlining Trim Moulding - (Falcon and Fairlane)
  • Article 726 - Removal of Locknuts Used to Secure the Jack, Spare Tire and Tools - (All Bronco except Station Wagon)
  • Article 727 - Wheel Opening Riding Heights - (All Models)
  • Article 728 - Front Door Access Panel Screws Loosening - (All 1961-65 Econoline and Conventional Trucks)
  • Article 729 - Exhaust System Clearance to Adjacent Vehicle COmponents - (All 1966 Fairlane Station Wagons)
cron
