January 1966 - December 1966
Bulletin No. 34 - March 25, 1966
(22 articles)
  • Article 681 - Inoperative Station Wagon Power Backlite in Subfreezing Temperatures - (1965 and 1966 Ford Station Wagons with Tailgate Power Backlite)
  • Article 682 - Hard Hot Starts - (All 1965-66 Light Trucks with 352 CID Engine)
  • Article 683 - Redesigned "U" Bolt Spacer for Hendrickson RU Suspension - (All "T" Models with Hendrickson RU Suspension)
  • Article 684 - Dana Rear Axle Cover Leaks - (F-100/350; P-350/400; P-3500-4000)
  • Article 685 - High Clutch Housing - Needle Roller Bearing Transmatic Transmission - (Heavy and Extra Heavy Trucks)
  • Article 686 - High Temperature Brake Fluid & EPT Seal Usage - (All 1965 Thunderbird)
  • Article 687 - Distributor Advance Curves - (1966 200 with Thermactor, 289 2V with Thermactor and 428 Police Interceptor Engines)
  • Article 688 - Parking Brake Retracting Spring - (1965 F-100/250 Trucks including 4X4)
  • Article 689 - Antenna Installation - (1966 Bronco - All Models)
  • Article 690 - Glove Compartment Door Drops Open on Rough Roads - (All 1965-66 Econoline with Padded Dash)
  • Article 691 - Front Suspension Attitude - (1965 F-100/250 Trucks)
  • Article 692 - Hood Support Rod Interference with the Upper Radiator Support when the Hood is in the Open Position - (1966 Bronco - All Models)
  • Article 693 - Seat Belt Installation and Legal requirements Associated with the Belt Specification Tag - (All Car Lines - All Models)
  • Article 694 - Cold Air Leak at Right Vent Duct - Integral Air Conditioner or Standard Heater - (1966 Falcon, Fairlane)
  • Article 695 - Oversize Kingpin Kits - (Econoline 1961-63; F-100/250 1957-64; P-100 1957-66; F-350 1957-66; P-350/400, 3500-4000 1957-66)
  • Article 696 - Electric Clock - Time Regulating Procedure - (All Models So Equipped)
  • Article 697 - Premature Ignition Point Erosion and/or Ignition Coil Failure - (1966 - All Ford Division Passenger Cars)
  • Article 698 - Malfunction of Fuel, Oil and Temperature Gauges - (All 1966 Ford, Thunderbird and Trucks)
  • Article 699 - Transmission Gear Shift Lever - (1966 Econolines with 3.03 Transmissions)
  • Article 700 - Rough Engine Idle - (289, 300, 330, 352, 361, 391 CID Engines)
  • Article 701 - Creaking Noise from Wheel Assembly During Cornering Maneuvers - (All 1965 and 1966 Thunderbird and 1966 Ford with Disc Brakes)
