January 1966 - December 1966
Bulletin No. 33 - March 11, 1966
(23 articles)
  • Article 658 - Poor Defroster Pattern - (All 1965-1966 Fords w/Integral Air Conditioners)
  • Article 659 - New Alternator Belt Tension Specifications to Correct for Loose Alternator Belts - (All 1966 Vehicles)
  • Article 660 - Cold Air Leaks and Air Conditioning Malfunctions - (1966 Falcon-Fairlane w/Integral Air Conditioning)
  • Article 661 - A/C Thermostatic Switch Malfunction - (1965-66 Ford w/Integral Air Conditioning)
  • Article 662 - Heater Core Moan, 45 to 60 MPH - (1966 Falcon, Fairlane w/Integral Air Conditioning) - (1966 Mustang - All Models w/Standard Heater)
  • Article 664 - Snow Entering Vehicle Through Heater or Air Conditioning - (1965-1966 Fords)
  • Article 665 - Heater / Defroster Discrepancies - (1965 Ford w/Standard Heater)
  • Article 666 - Cold Air Leaks, Integral Air Conditioning - (1966 Falcon, Fairlane So Equipped)
  • Article 667 - Wheel Shimmy and/or Premature Failure of Power Steering Cylinder Bushings - (1963 N-850/1000, NT-850/950, C-850/1000 and CT-750/950)
  • Article 668 - Vehicle Identification Number Location - Shop Manual Correction - (All 1966 Comet, Falcon, Fairlane and Mustangs)
  • Article 669 - Clutch Disc Failures - (1966 Ford 428 CID Standard Transmissions)
  • Article 670 - Cold Air Leak, Left Front Vent Duct Assembly - (1966 Falcon - Fairlane - All Models)
  • Article 671 - Horn Inoperative or Will Blow Constantly - (All 1966 Models except Thunderbird)
  • Article 672 - Short Circuits in Rear Lamp Housing - (1966 Thunderbirds Built Before October 1, 1965)
  • Article 673 - Rear Axle Vent Installation - (1966 Ford)
  • Article 674 - Engine Knock - (All Car Lines with 352-390-428 CID and Light Truck)
  • Article 675 - Stumble Problems - (170, 200 and 289 CID Thermactor Equipped Engines - All Ford Divisions Cars and Trucks)
  • Article 676 - Air Conditioner Refrigerant Charge Tag - (1966 Falcon - Fairlane w/Integral Unit)
  • Article 677 - Engine Knock - (All 289 CID Engines)
  • Article 678 - Loss of Power Assist on Power Brake Vehicles - (All 1966 Thunderbird Models, All 1966 Falcon and Fairlane Models with Power Brakes and All 1966 Fords, except Station Wagon Models with Power Drum Brakes)
  • Article 679 - Removal of Cable Type Exhaust Hangers to Improve Acoustics - (All 1966 Ford Models with V-8 Engines except 289-2V Sedans and Model 76 Station Wagons)
  • Article 680 - Main Oil Pressure Booster Valve Improperly Machined - (All Units Equipped with C6 Three Speed Automatic Transmission)
