January 1966 - December 1966
Bulletin No. 32 - February 25, 1966
(24 articles)
  • Article 634 - Bronco Front Axle Illustration - (All Broncos)
  • Article 635 - Oscilloscope Testing - (1966 Vehicles with Transistor Ignition)
  • Article 636 - Wheel Fight - (1966 F-100 4x4 Trucks and Bronco)
  • Article 637 - Adjustment Procedure for Air Operated Windshield Wipers - Trico and Sprague - (All 1964-65-66 H-HT and C-CT Trucks with Air Wipers)
  • Article 638 - The Doors Cannot Be Opened or Locked - (1966 Mustang - All Models)
  • Article 639 - Clutch Adjustment Procedures - (C, F, T, 8000 Trucks with C-160/180 Cummins Engines)
  • Article 640 - Parking Brake Cable Failures - (1964-66 F-100/250 Trucks and 1964-65 4x4)
  • Article 641 - Water Leaks in the Roof Side Rail Weatherstrip Area, Vent and Quarter Window Areas - (1966 Fairlane Hardtop)
  • Article 642 - 1966 Single Speed Windshield Wiper System Diagnosis Procedure - (All except Thunderbird)
  • Article 643 - Dual Action Tailgate Hinge and Lock Mechanisms - (1966 Ford, Fairlane and Falcon Dual Action Tailgate - Station Wagons)
  • Article 644 - Seat Track Binding and Outboard Tilting of the Bucket Seat - (All 1966 Fairlane and Falcon Bucket Seat Models)
  • Article 645 - Engine Spark Knock - (1965-66 352 CID Equipped Trucks)
  • Article 646 - The Center Floor Pan on the Driver's Side Deflects Excessively During Road Operation - (1966 Bronco - All Models with Bucket Seats)
  • Article 647 - Inadequate Adjustment of Remote Control Mirror - (1966 Fairlane and Falcon, All Models Equipped with Remote Control Mirror)
  • Article 648 - Windshield Wiper Linkage Failure - (1961-66 Tilt Cab Trucks with Parallelogram Air and Electric Wipers)
  • Article 649 - Accelerator Linkage Control Buzz and/or Rattle - (1966 6-Cylinder Falcon and Fairlane Built Before October 9, 1965)
  • Article 650 - Damaged Liftgate Weatherstrips - (1966 Bronco - Model 98)
  • Article 651 - Arm Rest Ash Receptacle Retainer - Poor Retention - (1965-66 Ford, Fairlane, Falcon)
  • Article 652 - Harsh Reverse Engagement - (1966 Thunderbird with Cast Iron Cruise-O-Matic Transmission - Model PCE-BJ)
  • Article 653 - Bronco Transfer Case - Lubricant Leak at Breather - (1966 Broncos - All)
  • Article 654 - Valve Train Prelubrication - (All Engines with individually Mounted Rocker Arms 221, 260, 289, 240 and 300 CID Series)
  • Article 655 - Insufficient Strength of the Liftgate lock release Lever and Bracket Assembly - (1966 Bronco - Model 98)
  • Article 656 - Service Horn Replacement - (All Car Lines)
  • Article 657 - Stone Damage of Rear Lamp Lens - (All Trucks with Ford Crest Tail Lamps)
cron
