January 1966 - December 1966
Bulletin No. 31 - February 11, 1966
(24 articles)
  • Article 613 - Eaton Axle Ring Gear Looseness - (Medium and Heavy Trucks w/Eaton Single Axles: 1790, 1880, 1614, 1618 or Eaton Tandem Axles 30-34-38 DS and RS, 34 MF and MR)
  • Article 614 - Speedometer Cable Routing - (1966 Fairlane)
  • Article 615 - Clutch Bell Housing Failures - 1965 and Prior Extra Heavy Trucks Equipped w/Fuller Model R-96 or R-960 Transmissions)
  • Article 616 - Thermactor Exhaust Emission System - (All Vehicles Thermactor Equipped)
  • Article 617 - Revised Reimbursement Procedure - Ford-Thompson Power Steering Pump Remanufacturing Program - (All Vehicles Equipped with Ford-Thompson Power Steering Pump)
  • Article 618 - Oil Filter - RT-RTO-910 Fuller Transmission - (Heavy and Extra Heavy Trucks)
  • Article 619 - Loose Bucket Seat Attachments - (1965-66 Thunderbird and Ford)
  • Article 620 - Dealer Replacement of Hub and Drum Assemblies - (All 1966 Cars Except Thunderbird and Ford Model 54E with 390-4V, 427-4V and 428-4V Engines
  • Article 621 - Spark Plug Specifications - (1966 Ford-Mercury)
  • Article 622 - Torque Specifications - (All Ford Vehicles with C4 Automatic Transmission)
  • Article 623 - Crankshaft Thrust Bearing Failures - (All with 330, 300, 361, and 391 CID Engines)
  • Article 624 - 1966 Shop Manual Engine Specifications - (All 289 V-8 Engines in Falcon, Fairlane and Mustang)
  • Article 625 - Starter Drive Failure - (All with 240, 289 and 300 CID Engines)
  • Article 626 - Counterbalance Assist Spring Rattle - (1965-66 Mustang Convertible)
  • Article 627 - Paint Chipping - (All 1965 Mustang)
  • Article 628 - Bubbles in Vinyl Top Material - (All Car Lines Equipped with Vinyl Roof Cover)
  • Article 629 - Bronco Front Spring Air Lift - (All Broncos Equipped with Air Lifts)
  • Article 630 - Wiring Short Circuit Tracing Aids - (All Cars and Trucks)
  • Article 631 - Front Door and Vent Window Wind Noise - (1966 Fairlane and Falcon - All Models)
  • Article 632 - Vinyl Tape Accent Stripe - (1966 Fairlane - "GT")
  • Article 633 - Safety Convenience Control Panel Lens Loose or Missing - (1965-66 Ford So Equipped)
cron
