Article 961 - Headlamp Retention and Adjustment - Ball Spring Failures
TSB #52 - December 2, 1966
(1966 Ford - All Models)
Technical Service Bulletin, article #597 dated January 28, 1966 outlines parts and procedure to correct the subject problem. A new ball spring (C6AZ-13031-B) that is easier to install and is less susceptible to over-stretching, is now available and should be used in place of the C6AZ-13031-A spring mentioned in article #597. The service class for the new spring is "B".
cron
