January 1973 - December 1973
Bulletin No. 39 - March 23, 1973
(9 articles)
  • Article 326-S - SERVICE BRAKE LINING KITS - REPLACEMENT (PART NUMBER CHANGE) - (1972 THUNDERBIRD/MARK IV)
  • Article 339-S - IMPROVED THROTTLE ACTION (PART NUMBER CHANGE) - (1971-72 CAPRI with 2000cc Engine)
  • Article 347 - DOOR ARM REST ASSEMBLY - CRACKED OR BROKEN - (1973 FORD/MERCURY)
  • Article 348 - HEATED BACK WINDOW - INOPERATIVE (BROKEN BUS BAR TERMINAL) - (1972-73 PINTO Model 64 (With Heated Back Window))
  • Article 349 - ROOF LUGGAGE CARRIER RATTLES AND/OR AIR DEFLECTOR SAGS - (1971-73 MODEL 71)
  • Article 350 - STATION WAGON LOAD FLOOR RATTLES - (1973 FORD/MERCURY - Model 71)
  • Article 351 - FRONT CAMSHAFT SEAL LEAKING - (1971-73 PINTO/CAPRI equipped with 2000cc Engines)
  • Article 352 - TIP-IN-MOAN - (1971-72 PINTO SEDAN With 2000cc Engine and Standard or Automatic Transmission)
  • Article 353 - SECOND GEAR JUMPOUT - (1972-73 4 x 4 & BRONCO, with 3 Speed Manual Transmissions)
