January 1973 - December 1973
Bulletin No. 40 - April 6, 1973
(12 articles)
  • Article 276-S - STONE DEFLECTOR - OUT OF POSITION AND/OR GAPS BETWEEN THE END AND CENTER PIECES - (1973 FORD/MERCURY, TORINO/MONTEGO AND THUNDERBIRD/MARK IV)
  • Article 354 - AIR LEAKAGE AROUND INNER DOOR HANDLES - (1973 FORD/MERCURY)
  • Article 355 - DOOR ARM REST - LIGHT BLEEDS THROUGH - (1973 THUNDERBIRD/MARK IV equipped with power windows)
  • Article 356 - DOOR GLASS RATTLES - (1973 FORD/MERCURY - Model 65)
  • Article 357 - FRONT DOOR ARM REST (AUDI STYLE ONLY) - CRACKED AND/OR BROKEN - (1972-73 PINTO - All Models; 1972-73 MAVERICK/COMET - All Models with Luxury Decor)
  • Article 358 - INTERMITTENT STICKING/BINDING OR INOPERATIVE MINI-VENT WINDOWS - (1973 FORD/MERCURY and 1972-73 LINCOLN Models Equipped with Mini-Vent Windows)
  • Article 359 - BRAKE PEDAL RATTLE - (1972-73 TORINO AND THUNDERBIRD and 1973 FORD/MERCURY With Automatic Transmission)
  • Article 360 - VARIATION IN AIR TEMPERATURE (BETWEEN RIGHT AND LEFT REGISTERS) DURING AUTOMATIC MODE SHIFT - (1971-72-73 LINCOLN With Automatic Temperature Control System)
  • Article 361 - DANA LIMITED SLIP AXLE NOISE OR "CHATTER" - 1973 AND PRIOR MODELS EQUIPPED WITH DANA FRONT OR REAR LIMITED SLIP AXLES)
  • Article 362 - DRIVESHAFT SLIP SPLINE BINDING AND/OR CENTER SUPPORT INSULATOR WEAR - (1973 F-100-350 WITH AUTOMATIC TRANSMISSION (Built Prior to November 6, 1972))
  • Article 363 - DRONING NOISE OR VIBRATION - (1973 BRONCO With Automatic Transmission)
  • Article 364 - INTERMITTENT RANGE SHIFT OPERATION - (1972-73 EXTRA HEAVY TRUCKS With Fuller RT-910, RTO-910, RT-9513, and RTO-9513 Transmissions)
