January 1973 - December 1973
Bulletin No. 44 - May 18, 1973
(8 articles)
  • Article 337-S - SOLENOID STARTER MOTOR - INTERMITTENT OPERATION........(1973 FORD and THUNDERBIRD, LINCOLN, MARK IV and MERCURY Equipped with Solenoid Starter Motor (429 and 460 CID Engines))
  • Article 380 - ANTI-THEFT ALARM SYSTEM - DOOR SWITCH REPLACEMENT - (1973 FORD/MERCURY So Equipped)
  • Article 381 - ASH TRAY AND CIGAR LIGHTER NOT INSTALLED ON SOME EARLY CARS (RIGHT ARM REST) - (1973 THUNDERBIRD - All with RPO Power Windows)
  • Article 382 - SURE TRACK BRAKE WARNING LIGHT STAYS ON AFTER ENGINE IS STARTED - (1973 MERCURY with Sure Track)
  • Article 383 - COLD START CONDITION - (1973 CAR LINES with 460, 429 and 351-4V Engines)
  • Article 384 - HOOD - LOOSE AT REAR - (1970-1973 TRUCK - "L" Series - Models N-NT)
  • Article 385 - OPERATION OF PANEL DIMMER SWITCH - (1972 "L" Series - Line Haul Models)
  • Article 386 - LOOSE SHIFT FEEL - (1973 BRONCO with Automatic Transmission and "U-Shift" Transfer Case Pattern)
