January 1973 - December 1973
Bulletin No. 47 - June 15, 1973
(5 articles)
  • Article 393 - IGNITION SWITCH RE-ADJUSTMENT PROCEDURE - (All 1970-73 Passenger Cars)
  • Article 394 - LUBRICANT LEAKAGE IN THE AREA OF THE REAR AXLE COMPANION FLANGE PINION NUT AND WASHER - (All Ford Design Rear Axles)
  • Article 395 - NEW FAN PULLEY SPACER AND BRACKET ASSEMBLY - (1973 L-LT-LTS-LN-LNT-8000 Series Trucks with Caterpillar V8 Diesel Engines)
  • Article 396 - TRANSFER CASE - HARD SHIFT - (1973 BRONCO with Automatic Transmission)
  • Article 397 - NEW FUEL TANK SELECTOR VALVE - (1970-73 "L" Series Trucks with Gas Engines & Dual Fuel Tanks)
