Article 1160 - Fuel Shut-Off Solenoid Installation Procedure
TSB #76 - September 29, 1967
(1967 B, C, F and N-6000/7000 Series Trucks)
The fuel shut-off solenoid installation procedure has been changed to insure full travel of the operating lever on the fuel injection pump. The operating lever should be locked with solenoid energized and the shut-off valve in the "On" position. Prior to this, the lever was locked with the solenoid de-energized and the shut-off valve in the "Off" position.
The attached Fig. 1 identified these parts.
cron
