Read this prior to navigating/searching the database
What is a TSB Summary?
A Technical Service Bulletin (TSB) Summary is a summarized (abbreviated) article, published in a Technical Service Bulletin Index.
As an aid to the service technicians, Ford would periodically release a TSB Index. This Index contained Summaries of previously-published TSB articles, but typically didn't include graphics, tables and/or part numbers. The Summary would simply 'remind' the technician what information the actual article contained and where to find the full article. In some cases, if the actual TSB article was already short (a paragraph or two), the entire article would be reprinted in the TSB Index. However, if the TSB article is longer, and contains tables with part numbers, a lengthy repair/adjustment procedure, etc, then the Summary article tells the Technician what information is contained in the full article and where to find it. This made it much easier to index and search through several years worth of TSB releases quickly.
For example:
Fig 01 (below) shows an example of the TSB Index. This one contains TSB article summaries for January 1967 through December 1969 and contains 88 pages.
FIG. 01
You can see how the article summaries are sorted by subject, to make finding a specific article much easier. Let's say a technician recalled reading an article discussing the free play settings for the accelerator pedal on Ford pickups. By looking under the 'Fuel System' subject listing on the front page of the TSB Index (Fig. 01), he sees the listing for 'throttle linkage' listed on Page 47. So he turns to Page 47 in this TSB Index and sees this:
FIG. 02
He then quickly scans the page and sees that the first article summary on this page is entitled "Accelerator Pedal Free Play and/or Irregular Return to Idle". He reads it, and notes that the summary specifically tells him that "..full instructions and part numbers are contained in the article...", which is then shown as having been published in TSB #99 dated 9/27/68 as Article #1489.
The technician is then able to pull the appropriate 3-ring binder which contained all the TSB releases. He finds TSB #99, as shown below (Fig. 03)
FIG. 03
He then searches this 8-page TSB for Article #1489, which happens to be on the front page, and reads the complete article, which contains the necessary part numbers and adjustment procedures for correcting his customer's complaint.
So why does the FORDification TSB Database contain Summaries instead of the full article?
That's easy to answer....because in some cases I don't have the actual TSB release containing the full article, though I DO have the TSB Index, which contains the summaries. By at least publishing the summaries in cases where the full TSB article is unavailable, you're able to get an idea of what information the full article contains. As mentioned above, in some cases the summary actually does contain the full text of the TSB article. In other cases, the summary will simply reference the full article as containing additional information.
Why does the FORDification TSB Database only contain Summaries for some model years and not for others?
Apparently Ford decided that the Article Summaries were unnecessarily repeating already-published articles or that by eliminating the Article Summaries from future TSB Indexes they could include a larger article listing in the same amount of space. Therefore, starting in late 1972, the Article Summaries were eliminated from the Ford TSB Indexes, and the indexes included only the article title, vehicle application and TSB Article Number/Date.
