Article 1272 - Front Pump Check Valve (Correction to 1968 Ford-Mercury Shop Manual)
TSB #85 - February 9, 1968
(1968 Ford with FMX-MX Automatic Transmission)
The transmission front pump check valve and spring, formerly located in the regulator assembly, were removed from the subject transmissions, effective Job 1, 1968.
The 1968 Ford-Mercury Shop Manual should be corrected as follows:
  • Page 7-83 - Fig. 46 - Remove the front pump check valve and spring from the illustration.
  • Page 7-83 - Under the paragraph entitled Pressure Regulator, delete the second sentence from Step 3 and delete Step 10 entirely.
cron
