Article 1264 - Limited Clearance - Shift Lever to Steering Wheel
TSB #84 - January 26, 1968
(1968 Ford and Fairlane Equipped with Column Mounted Standard Transmission)
Some 1968 Ford and Fairlane vehicles with standard transmissions built before November 10, 1967, reportedly may have a condition of limited clearance between the steering wheel and shift lever in first and reverse gear positions. On a customer complaint basis only, this condition may be corrected by replacing the shift lever, with a new lever, part number C8AZ-7210-K.
WARRANTY STATUS - REIMBURSABLE
Oper: 7210-A Time: 0.3 hrs.
cron
