Article 1282 - Change in Lubricating Oil Specifications
TSB #85 - February 9, 1968
(1967-1968 242 and 363 CID Ford Dorset Diesel Engines)
Multi-viscosity lubricating oils meeting Ford Specification ESE-M2C101-B may now be used in the subject engines (single-viscosity oils only were formerly specified). Single viscosity oils may still be used, if they meet Specification ESE-M2C101-B rather than the Military Specification MIL-L-2104A (S-l) formerly specified. Use the temperature-viscosity chart given below for crankcase refill:
MULTI-VISCOSITY OILS
When Outside
Temperature Is
Consistently
Use SAE
Viscosity
Number
Below +32° F
-10° F. to +90° F
Above 0° F
Above +32° F.
5W-30
10W-30
10W-40
20W-40
SINGLE VISCOSITY OILS
When Outside
Temperature Is
Consistently
Use SAE
Viscosity
Number
-10° F to +10° F
+10° F to +32° F
+32° F to +90° F
Above +90° F.
10W
20-20W
30
40
Page 4-2 of your 1968 Ford Truck Maintenance and Lubrication Manual should be corrected to show the new specification. The next printing of the Truck Owner's Manuals will show the new specification, also.
cron
