Article 2049 - Master Cylinder to Spring Tower Interference
TSB #131 - January 16, 1970
(1970 Fairlane with Power Brakes)
On a customer complaint basis in the engine compartment area, inspect the spring tower for evidence of contact with the master cylinder and/or bleed screw. If there is evidence of contact, remove and support the master cylinder assembly away from the spring tower. Indent the spring tower sheet metal inward 1/4" at the center of contact mark with a ball peen hammer. Install master cylinder assembly.
WARRANTY STATUS: REIMBURSABLE
Operation: SP-2140-A-70
Time: 0.2 Hr.
DLR. CODING: Defect Code - 56
cron
