Article 3247 - Clutch Pilot Bearing Noise - Light Truck
TSB #157 - January 22, 1971
(F100-F350 Truck with 8-Cylinder [360-390 CID] Engines and Standard Transmission - 1970-71)
"Squeal" and "chirping" noise caused by a dry pilot bearing can be reduced by installing a new improved bearing.
NOTE: It is very important that the replacement bearing be soaked in SAE 30 non-detergent oil for a minimum of one-half hour. All excess oil should be wiped off the surface of the bearing prior to installation.
PARTS:
Part NumberPart NameClassAvail.
B8AZ-7600-APilot BearingAOK
PRODUCTION CORRECTION: 12-14-70.
WARRANTY STATUS:
Reimbursable within the provisions of the Warranty & Policy Manual.
Time: In compliance with Time Standard Book.
DLR. CODING: Basic Part No. 7600 - Code 51
cron
