Article 3255 - Loose Front Engine Mount - New Bolt
TSB #157 - January 22, 1971
(L, LN, LNT, LT, LTS, W, WT-9000 with NH, NHC, NTC & 8V-71 Diesel Engines - 1970)
A new 12-point bolt can be used to replace the original hex-head bolts. The new bolt permits higher torque. Bolt torque specification increases from 110-150 to 150-205 ft. lbs. See Figure 9.
PARTS:
Part No.Part NameReq'd.ClassAvail.
384656-S212 Point Bolt2SOK
PRODUCTION CORRECTION: 5-18-70.
WARRANTY STATUS:
Reimbursable under provisions of the Warranty & Policy Manual
Time: Actual time as defined in the Warranty & Policy Manual, Introduction Section, Page 5.
DLR. CODING: Basic Part Number 6028 -Code 57
cron
