Article 3258 - Engine to Radiator Aspirator Hose Chafes on Air Cleaner Flange
TSB #157 - January 22, 1971
(L-Series Trucks with Cummins NTC and NHCT Engines - 1970)
(THIS ARTICLE CANCELS AND SUPERSEDES ARTICLE 2371, BULLETIN 143)
Bulletin No. 143, Article No. 2371, outlines a correction for the radiator aspirator hose interference with the air cleaner flange. In some instances, the hose may still interfere with the air cleaner flange because of fitting position and hose length.
This condition, if encountered, may be corrected by securing the hose to the water filter housing with an adjustable nylon strap.
PARTS:
Part NamePart No.Req'd.ClassAvail.
Nylon Strap383313-S1BSOK
PRODUCTION CORRECTION: 11-2-70.
WARRANTY STATUS:
INFORMATION ONLY
cron
