Article 3259 - Air Conditioner Evaporator Drain Tube Improperly Installed
TSB #157 - January 22, 1971
(Pinto - 1971)
Wet front floor carpeting on A/C-equipped Pintos may be the result of an improperly installed evaporator drain tube. Check the forward drain tube connection from the plenum case to the floor pan for proper installation.
cron
