Article 3260 - Starter Relay Solenoid Switch Replacement
TSB #157 - January 22, 1971
(Pinto - 1971)
When the Essex (RBM) design relay (Engineering number stamped on metal face — C7AF-11450-A1) is used on a 1971 Pinto, the rearward stud terminal must be used for the positive battery cable to properly reach the relay (either stud terminal can be used as the battery terminal on these relays). See Figure 11 for correct cable connections to the RBM design relay.
cron
