Article 3266 - Clutch Disc
TSB #158 - January 29, 1971
(Pinto - 1971)
It is important that clutch discs are not replaced for loose springs when performing clutch service. The Pinto clutch disc has been intentionally designed to provide a loose fit for the springs. This insures proper dampening of transmission noises, but does not rattle during operation. It should also be noted that service replacement parts have the same spring design.
cron
