Article 3276 - Radiator Side Air Deflector
TSB #158 - January 29, 1971
(All "L" Series Trucks)
The radiator side air deflector assembly consists of a rubber strip stapled to a metal strip which is bolted to the radiator or shutter box side supports. Should the rubber strip separate from the metal strip, reinstall with "pop-rivets".
A backup washer must be used on the rubber strip to prevent rivet pull-through.
PRODUCTION CORRECTION: 11-2-70
WARRANTY STATUS:
INFORMATION ONLY
cron
