Article 101 - Excessive Engine Oil Consumption
TSB #9 - January 14, 1972
(1970-71 401, 477, 534 CID Truck Engines with Dry Type Air Cleaners)
Excessive engine oil contamination may result from unfiltered air entering the crankcase.
Since crankcase air is taken from the unfiltered side of the air cleaner, the aluminum crimp packing does not thoroughly filter the incoming air.
To correct, replace the present filler caps with Part No. C4TZ-6766-B, which contains hair packing filter material.
PART NUMBERPART NAMEREQ'D.CLASS
C4TZ-6766-BOil Filler Cap2A
PRODUCTION CORRECTION: 11/29/71
WARRANTY STATUS:
DLR. CODING: Basic Part No. 6766 - Code 40
cron
