January 1967 - December 1967
Bulletin No. 58 - January 27, 1967 [COMPLETE]
(10 articles)
  • Article 980 - Static Noise in Radio Speakers - (1967 Thunderbirds)
  • Article 981 - Clutch Release Equalizer Bracket-Ball Stud Failures - (1966 and post Model F-B-500-750 Trucks with 240, 300, 330, 361, and 391 C.I.D. Engines)
  • Article 982 - Modification Special Service Tool T65P-3000-D Caster Camber Adjuster - (1967 Thunderbird)
  • Article 983 - Second Gear Jump-Out (Warner) - 3 Speed Overdrive Transmissions - (1965-1966 Model F-100 Trucks)
  • Article 984 - Steering Drag Link Installation - (1967 F & B 500-750 with 5000-7000 Lb. Front Axles and Power or Manual Steering)
  • Article 985 - Back Window Moulding Installation - (All Car Lines)
  • Article 986 - Seat Belt Warning Light - Reduction in Illumination Time - (1967 - All Car Lines)
  • Article 987 - New Auxiliary Transmission Case Assembly - Spicer 7041 - (Heavy and Extra Heavy Trucks with Spicer 7041 Transmission)
  • Article 988 - Transmission Fluid Leaking From the Intermediate Servo Lever Shaft Hole - (1966 and 1967 Passenger Cars Equipped with the C6 Automatic Transmission)
  • Article 989 - Rough Idle Diagnosis - (All 1967 8-Cylinder Engines except 427 CID)
