January 1968 - December 1968
Bulletin No. 094 - June 21, 1968 [PARTIAL]
(24 articles)
  • Article 1422 - Inadequate Cooling - (1967 Thunderbird Equipped with Integral Air Conditioning Heating System)
  • Article 1423 - Displaced and/or Leaking Oil Gallery Drive (Cup) Plugs - All Engines So Equipped - (All Car and Truck Vehicles)
  • Article 1424 - Tachometer Diagnosis - (Model "C" Cortina GT)
  • Article 1425 - Engine Ignition Noise in AM Radio (Supplement to Article #1379) - (All Car Lines with Philco AM Radio)
  • Article 1426 - Engine Knock on Acceleration - Transmission Flexplate to Crankshaft Retaining Bolt Torque - (Cortina Model "C" Units with Automatic Transmission)
  • Article 1427 - Field Replacement of Stylized Steel Wheels - (1968 Mustang and Fairlane)
  • Article 1428 - Back-up Lights Inoperative - (All Model "C" Cortinas Except Station Wagons)
  • Article 1429 - Replacement of Deluxe Sports Steering Wheels - (All 1967 Mustang, Fairlane and Ford "7 Litre" Vehicles So Equipped)
  • Article 1430 - Improved Brake Lining - (Medium and Heavy Trucks Equipped with 15" x 3" Front and 15" x 6" or 15" x 7" Rear Hydraulic Brakes)
  • Article 1431 - Front Hub and Brake Disc Assembly - (All Cortina Models)
  • Article 1432 - Brake Rotor Refinishing Specifications - (All 1968 and 1969 Passenger Cars Equipped with Front Disc Brakes)
  • Article 1433 - Intermittent or Inoperative Windshield Wipers - (1968 Ford - Custom, Custom 500 and Ranch Wagon)
  • Article 1434 - Air Intake Hose and Tube Installation - (1967-68 "W" Series Trucks - All Engines)
  • Article 1435 - New Starter System "Delayed Reingagement" Control Relay - (All 1968½ 428 CID Engine Equipped Units)
  • Article 1436 - New Exhaust Valves - Super Duty Engine - (1958-68 401, 477, 534 CID Truck Engines)
  • Article 1437 - New Cylinder Heads - FT Truck Engines except 330 MD - (1964-68 330 HD, 361, 391 CID Engines)
  • Article 1438 - New Vacuum Supply Fittings - (All 500-1000 Series Trucks Equipped with Hydraulic Brakes and Vacuum Boosters)
  • Article 1439 - Improved Material Rear Engine Mount Bolts and Lock Nuts - (1967 and Past model N1000-D and NT-850-950-D with Cummins NH and Detroit Diesel 6-71 Engines
  • Article 1440 - Rear Seat Back Filler Misalignment - (1968 Thunderbird Models - Less R.P.O. Center Arm Rest)
  • Article 1441 - Erratic Operation of the Temperature and and Oil Pressure Gages - (1968 Broncos Built Between 1-1-68 and 3-20-68 )
  • Article 1442 - Floor Pan Flange Interferes with Oil Filter - (1969 Econoline - All Models Equipped wit 8-Cylinder Engine Built Prior to March 5, 1968)
  • Article 1443 - Improper Warranty Diagnosis and Repair
  • Article 1444 - Tune Up Specifications For Liquid Petroleum Fueled 330 HD, 361 and 534 CID Engines - (1966-68 D.S.O. Truck Engines)
  • Article 1445 - Engine Idle Speed Specification - (1968 Econoline with 170 CID Engine, Thermactor and Standard Transmission)
cron
