January 1968 - December 1968
Bulletin No. 088 - March 22, 1968 [PARTIAL]
(18 articles)
    - Article 1323 - Servicing Floating Caliper Disc Brakes - (1968 - All Models So Equipped)
    - Article 1324 - Power Steering Leaks at Inlets and Outlet Ports of the Ford Integral Gear (XR50) - (All)
    - Article 1325 - Pinion Nut - (Cortina)
    - Article 1326 - Crankcase Emission Control Valve (Fully Closed Ventilation System) - (1967 Cortina)
    - Article 1327 - Clutch Pressure Plate Degreasing - (All Cortinas Equipped with Manual Transmissions)
    - Article 1328 - Automatic Climate Control System Operation and Modification of Units Built Before November 6, 1967 - (1968 Thunderbird)
    - Article 1329 - Field Correction for Limited Slip Clutch Plate Chatter - (All Ford Built Axles with Limited Slip Differential)
    - Article 1330 - Gearbox Extension Housing Bearing - (Cortina - In line and "V" Engine)
    - Article 1331 - Passenger Seat Reinforcement - ("W" Series)
    - Article 1332 - Seat Cushion Noise or Sag - (All 1967-68 Trucks with Conventional Cabs)
    - Article 1333 - Correction to the 1968 Ford-Mercury Shop Manual - (1968 Ford and Mercury)
    - Article 1334 - Change in Door Courtesy Light and Map Light in 1968 Ford Car Service Specifications Booklet - (1968 Thunderbird)
    - Article 1335 - Possible Cause of Carburetor Flooding - 240 CID Engines - (All 1968 Light Trucks with 240 CID Engine and Standard Transmission)
    - Article 1336 - Pre-Delivery Inspection of Radiator Hose and Clamp Installation - (1968)
    - Article 1337 - Sleeper Cab Supports - (All "W" Series Sleeper Cabs)
    - Article 1338 - Ford Built Rear Axles - Lubricant Capacities and Specifications - (1967-1969 Econoline, 1967-1968 Broncos and F-100 Light Trucks)
    - Article 1339 - Rear Cab Mounts - (F, N, NT and T-500/1000)
    - Article 1340 - Cab Locking Mechanism Adjustment - (All "W" Series)
cron
