January 1968 - December 1968
Bulletin No. 089 - April 5, 1968 [PARTIAL]
(14 articles)
    - Article 1341 - Revised 1968 Exhaust Emission System Air-Fuel Ratio Specifications - (All 1968 Passenger and Light Truck Units with Exhaust Emission Systems)
    - Article 1342 - Air Conditioner Expansion Valve Diagnosis Procedure - (All Air Conditioner Equipped Vehicles)
    - Article 1343 - Improper Choke Operation - 1968 Thunderbird - (1968 Thunderbird [429 CID Engine] - Carburetor Models C8SF-E & C8SF-G)
    - Article 1344 - Door Outer Panel Reinforcement at Belt - (1967-68 "W" Series)
    - Article 1345 - Flattened Tailpipes - (1968 Fairlanes)
    - Article 1346 - Refrigerant Lines Damage to Improper Installation of Support Clamp - (1968 Fairlane and Falcon Equipped with 8 Cylinder Engines and Air Conditioning)
    - Article 1347 - Limited Clearance Between Stake Platform Body and Rear Tires - (1967 U.S. Army F600 Trucks with 14' Stake Platform Body)
    - Article 1348 - Ignition System Tests - (All Vehicles Covered in Ford-Mercury CFFMM and Bronco-Econoline Shop Manuals)
    - Article 1349 - Starter Failure to Engage - (All Trucks Equipped with 8V-71 Diesel Engine)
    - Article 1350 - Rear Engine Mount Bolts - (C-8000 Vehicles with Cummins C-CF-160 and CF-180 Engines)
    - Article 1351 - Steering Column and Flexible Coupling Installation - (1967-68 F-100-350 Model Trucks)
    - Article 1352 - Ignition Vacuum Schematics - (1968 Ford Car with 240 Engine, IMCO Emission and Automatic Transmission)
    - Article 1353 - Sheet Metal Reinforcement ( "C"Series)
    - Article 1354 - Service Procedure for Instrument Cluster Gauges - (All 1967-68 Vehicles)
