January 1968 - December 1968
Bulletin No. 090 - April 19, 1968 [PARTIAL]
(13 articles)
    - Article 1355 - Premature Spark Plug Fouling - (All 1968 302, 390 and 428 CID Engines Except the 390-4V GT, 428 Police Interceptor and 428 Cobra-Jet Packages)
    - Article 1356 - Intermittent or Inoperative Instrument Panel Lights - (Model "C" Cortina)
    - Article 1357 - Battery Cable Chafing on Battery Tray Edge - (1967 Cortina)
    - Article 1358 - Thermactor Emission System - (1968 F-100 with 360/390 CID Engine and Standard Transmission)
    - Article 1359 - Stoplamps Remain Illuminated - (1966, 1967 and 1968 Thunderbirds Equipped with Speed Control)
    - Article 1360 - Seat Track Adjustment to Correct Binding - (1968 Thunderbird, All Models)
    - Article 1361 - Loose Pick-Up Box Hold-Down Bolts - (1968 F-100-350 Light Trucks)
    - Article 1362 - Spark Plug Removal - 1968 Fairlane and Mustang Units with 390, 427 or 428 C.I.D. Engine Packages)
    - Article 1363 - Snapping Noise and/or Water Leak at Front Door Window Frame - (1968 Fairlane - Models 63, 65 and 76)
    - Article 1364 - Imported Vehicle Tools - (Imported Vehicles)
    - Article 1365 - Cortina Timing Pulley - (All 1968 - U.S. Only)
    - Article 1366 - Possible Misalignment of the Crankshaft Pulley to the Crankshaft Damper - (1968 Model 289 CID and 302 CID Engines)
    - Article 1367 - Rear Axle Pinion and Differential Bearing Pre-Loads - ("68 Cortina")
